Group: DynoMotion Message: 43 From: Azd Md Date: 8/31/2009
Subject: Can I use Code Composer Studio with Kflop?
I have algoerithms with morer complex data types such as structurs and classes. does the Kflop supports that, or is it possible to use Code composer studio directly with Kflop and Kmotion boards.
Group: DynoMotion Message: 44 From: Tom Kerekes Date: 9/1/2009
Subject: Re: Can I use Code Composer Studio with Kflop?
The included free TCC67 C compiler is 99% ANSI C compatible so complex structures and such are certainly possible.  But TCC67 is a C compiler not a C++ compiler (no classes).
Texas Instruments CCS can be used.  The COFF output file format (*.out) is compatible with TCC67 and loadable with our loader routines.  Also TCC67's debug information is compatible so TCC67 programs can be debugged with CCS.
However what is missing is a way to link calls from code you might write using CCS to make calls into KFlop/KMotion code.  TCC67 has a special feature to read in the symbol table from a COFF file to resolve external references.  I'm not aware of a similar capability for the TI compiler.  As a workaround if your code only needs to reference a few functions and variables you could print the addresses of those symbols using a TCC67 program then hard code them into your code.
So the short answer is that it is possible but with some difficulties.
